62vauxhall
- May 14, 2014
- Southwest Kootenays BC
What 5 watt bulbs? The meter lamps are 8 V at 55mA and that is only .44W each so less than 1watt consumption. I do not know of any 5 watta bulbs in these units.
The 24 Vdc supply feeds the Audio section and the Bias Oscillator not the lamps. The lamps are fed from a seperate 6.3Vac tap off the transformer- you may have this unit wired up by a Yahoo technician and so you need to put it back the way it was designed. If you open up the fuse link in the transformer then you will be opening up and trying to do surgery on a transformer which I bet will not be fun- I have done them but I would rather avoid such work. The amount of current the deck using at most would be in record mode but the LM7824 propertly heat sinked will not ge that hot from what is normally drawn from the supply.
The two 5 watt 12 volt bulbs in series are automotive bulbs, probably for interior dome lights. Nothing to do with the deck. I obtained them for testing purposes only - the 24 volt output of the power supply.
