Joe, could you explain these specs then. I don't understand any of it
Specifications:
PRE-AMPLIFIER SECTION Input Sensitivity High Gain (moving coil)............175μVrms @ 1kHz Low Gain (moving magnet).......1.8mVrms @ 1kHz Compact Disc...........................................350mVrms All other inputs........................................110mVrms Input Impedance High Gain (moving coil).................................47kΩ Low Gain (moving magnet)............................47kΩ Compact Disc..................................................20kΩ All other inputs...............................................25kΩ Input Overload High gain...................................120mVrms @ 1kHz Low gain...................................900mVrms @ 1kHz All other inputs.............................................50Vrms Rated Output...............1.5Vrms into 10kΩ or higher Maximum Output........27Vrms into 10kΩ or higher Main Output, Source Impedance..................470Ω Tape Output Level.......................................110mV Source Impedance.............................................2kΩ Minimum Recommended Load Impedance.10kΩ
Distortion (THD and IMD) Phono inputs 0.005% 20Hz-20kHz rising to 0.01% before overload All others less than 0.0009% 20Hz-20kHz at rated output Noise (inputs loaded) Phono, high gain (unweighted)-64dB re rated input Phono, high gain (A weighted).-72dB re rated input Phono, low gain....................-86dB re 10mV input Phono, low gain (unweighted).-78dB re rated input Phono, low gain (A weighted)..-86dB re rated input All others (unweighted).......-104dB re rated inputs All others (A weighted)........-108dB re rated inputs Frequency Response Output stage........................20Hz-50kHz, ±0.25dB Channel Separation All inputs..................................70dB 20Hz-20kHz Phase Accuracy............................±1° 20Hz-20kHz
