62vauxhall
- May 14, 2014
- Southwest Kootenays BC
They are warmer but you can’t feel the area that they are warmer, on the die attach side between the base and emitter pins. The transistor cans are steel and don’t conduct heat like aluminum does
Thanks for explaining. It seemed odd.
And thanks again also for the guide through to finding the problem. All that's left now is an effective cleaning method for the insides of the RCA jacks. They're housed in a plastic.
Going to try pipe cleaner bent triple, soaked in contact cleaning liquid.
