That is a good sign. Now for the last reversal, reconnecting the collector of Q605 again and seeing what you get.R627 reconnected and voltage still positive and still at (+)52 volts.
Bingo, you found your culprit. A wounded transistor from the one being put in backwards in the Q605 location that you discovered.Reconnecting Q605's collector caused voltage to change from (+)51 volts to approximately (-)0.8 millivolts. And the amp did not go into protection.
I'd be more confident if Q605 was replaced, it's a 2SC1628. As is it's partner, Q606.
I mentioned earlier on page 4 - post #80 (jeez this has run long), that I have KSC3503 which are supposed to sub for 2SC1628. Would you agree....put KSC3503's at Q505 & Q606?
Re the outputs: All have been removed from both channels. When I install two, I'll do so two on each channel. And at this stage, I should be using the new ones, not what good ones are left of the old batch?
EDIT: DBT has been in use all along. Will continue doing so while installing the outputs.
Many thanks Joe, I am actually beginning to imagine and end to this thing.
Yes, an MJE15033 is at Q603. And KCS3503's are at Q605 & Q606. Voltages are within a few millivolts of 0 volts and protection is not engaging.
It must wait until tomorrow but I'll do as you say re the outputs and installl originals in only the left, as you say "dog", channel for now. Two at a time with DBT. I'll not install any outputs in the working right channel.
I noticed that bias still remains non-adjustable at 0.0 volts with no output transistors in place. Presumably that will not be so when some are installed?
If/when the left channel is restored to functionality with original outputs in place, I'm assuming the next step would be to proceed putting in the new outputs? Again, two at a time in both channels with DBT and final bias adjust will be without DBT?
You have to be a fossil to know that a VTVM is a vacuum tube voltmeter which was replaced by most any DVM.
The new outputs are in and bias (no DBT) is now at 30mv as per service manual.
There is another adjustment in the manual referred to as DC Balance Adjust but to perform that, according to instructions, a VTVM is needed. I do not have one of those. A DMM does not seem useful. I guess it’s not capable of a stable zero volt reading.
I’ve only been inside a few amplifiers and have not encountered this adjustment before.
Is it critical?
I observed the heat sinks are warmer at idle than the output transistors themselves. I expected the transistors would be at least just as warm. A sign of good heat sinks?
Offset at speaker terminals are negatives (-)7mv & (-)15mv.
Tomorrow I’ll hook up speakers, a line & phono source.
Were you on DC range Gary?
