I’d call it the wolf.
			I gotta apologize to Lee for laughing at the 400's over these last 5 or 6 years.......................
BUT, on the other hand, 2 400's were gifted to me and it does cost as much as a 700B/II to WOPL but if yer gonna wopl a 400, do it with a free one otherwise, the extra power of the 700 is where it's at. I guess I can wopl this 700B and sell it since the 400 II will be keeping the party going.
Yep, a 400 WOPL is no slouch.I gotta apologize to Lee for laughing at the 400's over these last 5 or 6 years.......................
Perry, I have the older PL400 with analog meters, any way to make the 700 face plate work with the analog meters of the 400 for the benefit of the on/off switch and volume pots?
No easy way. You need 700b meters as they are inverted design. Find some small Alps volume pots and switches and drill the existing plate may be your best betPerry, I have the older PL400 with analog meters, any way to make the 700 face plate work with the analog meters of the 400 for the benefit of the on/off switch and volume pots?
Thanks for the reply, got to ask just in case
Stetter,Perry, I have the older PL400 with analog meters, any way to make the 700 face plate work with the analog meters of the 400 for the benefit of the on/off switch and volume pots?
I suspect that the WOPL 400s2 puts out a bit more that 400 rms, any of you guys measured the actual output?
Interesting you should mention FredR, I have one of his WOPL400s with the pots and holes drilled as my main system power while I rebuild my original PL400. no on/off switch thoughStetter,
Dig around for some posts by FredR, he has added some controls to the 400’s with VU meters I just can’t remember if they were volume pots or and on/off control. Like Glenn said they have to be small pots or switches as there isn’t much room in there.
250 a channel .05% N+THDI suspect that the WOPL 400s2 puts out a bit more that 400 rms, any of you guys measured the actual output?
