- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Ahh cool, so you don't have to turn it down?![]()
Her other name is "she who must be obeyed"..
That is seriously kickass Jer
* groan *
already thinking about looking around for a 700b though finding one on my budget would be a challenge LOL
Dave....
Why it never manifested to where I could hear it here I'll never know, but... I do believe while replacing the RCA's and bypassing the pots I found the real cause of your hum. I was checking resistance to ground (making sure the new RCA's were isolated), and part of that is just a quick verification I had good ground on the chassis from the main star/cap ground.
Well, turns out... the chassis itself was NOT hooked up to the star ground, at ALL. Man it's the simple stuff one assumes to be there!! Basically the chassis was floating out there, catching any and all nasty stuff!
I figured I'd bring this up with ya, as we left this situation not quite "optimal" and you not benefiting from a full WOPL'd experience. Let me know if (perhaps) you might be interested in not only a WOPL'in but with the backplanes coming around the corner AND nice brand new caps in April you'll be getting on hell of an amp out of one of the others ya got!
Even if the switch was grounded at one time or another, that is not how we ground the chassis. Instead, between the two main tie points and specifically held by the screw and nut combos is a white wire - that is not only supposed to go between the two tie points, but another wire should have been between the left tie point and cap/star ground. Single point ground to prevent any ground loops. I'd assumed it was in place, when it turns out it was not. In any case, I can definitely say there was a complete "open" between the chassis and star ground when I checked it last night and THAT was your issue with the hum... not a doubt in my mind.
In any case... No fear... when the backplanes become available it is THIS 700B that I plan on converting first. All goes well... you're welcome to try yourself or send one this way.
Alrighty then...
Yeah wow... whatever this "mila mod" is all about, it's all gotta go. I have 100 ohm resistors going to places that just aint normal (not to mention they should be 10), both flavors of emitter resistors neither being .33's or .22's, and just.. weird.. heheh.
Anywhoo.. work has begun in earnest. Stripped off the positive side of the left channel so far, now time to open Lee's box of fun...
(pardon the blur... gotta go get the "good camera" in a few... )
My fault Lee. If I re-read my own thread, it's obvious. Apologies. Ok.............I have a good candidate for a White Oaking in the future here. In the mean time....... I can't decide for now on blue or White? They both look fantastic. A comparo still makes it's tough...........
