- Jan 14, 2011
- Gillette, Wyo.
You're not blowing 8 amp fuses are you?
OKay, what now. 240 wasn't near it's potential...
Ok, gotcha. I did not realize you were doing a sine wave test therefore, I am still running somewhat safe then. The preamp has not caused me any issues since but the amp does heat up pretty fast when I am cranking. Starting to wonder if the published specs of my E-7127 being 8 ohms is wrong. It heats up so fast that I would think they are 4 ohm. As long as I have the monster box fan sitting on top blowing max speed when I am feeling loud, the amp performs flawlessly and the fins feel pretty cool. It just looks stupid as hell but blowing up the amp for not using it would be even more stupid
Ron - remember that speaker impedance varies over frequency so they could be dipping down to something less than 8 ohms. I don't know how much the E-7127 speaker impedance varies but that is something you should take into consideration.
Isn't there supposed to be a trace here? Between 34,35?
On the backside Lee...Isn't there supposed to be a trace here? Between 34,35?
I think this was the beta board, so quasi was not the goal. Just wondered if Joe knew this.
Sorry Dennis, I typo'd and extra 7, they are E-712's
http://reviews.cnet.com/separate-speakers/cerwin-vega-e-712/4505-7869_7-6899368.html
OK, then you moved it to the topside later?
I have an early and late "D" board on the later one both interconnects are on the top, on the earlier they are top/bottom..
