- Jan 14, 2011
- Gillette, Wyo.
Do you want to simulate a blown fuse , or push and see if it goes?
Well yeah, right now. You're calling down changes and I'm makin em. It seems the only way to see if that was a cure is to duplicate the push.
R35 in. got a little rough with Q7R last time and ripped the base trace, thank goodness that doesn't see much. Managed to get a small sliver back in the hole and a good solid solder job.
I would rather push it and see if it (what) goes Lee. You are the master of pushing things over the limit![]()
I'm losing the positive rail fuse at 240 watts at 8 ohms. Did it twice. The minus rail fuse does not look stressed. It did not take out the pico fuse, either one.
Q 7's are fine...
The B+ rail fuse was blown.
That is about spot on where a 5A fuse should blow Lee with you pulling 240W x 2 channels into 8 ohms.
