- Jan 14, 2011
- Gillette, Wyo.
You should be able to open the 2 connect points to the cap screws to prove that Lee.
Gotcha.
The star point ground from the boards.
Nice trick, infinite on all collectors, base and emitters.
Broight it up all the way without rail fuses, bulb went way bright long after the caps were charged, then went dim immediately. Stuck rail fuses back in. Offset -11, -13. Damned if I know, both q7's cool, piece of .010 solder finally melted?
If you've lost faith in the Spec 2 I will gladly love it and care for it the rest of my life...
Resting my case
