I'll get into trouble if I explain my plucking process
Removing the egg involves a rubber glove and vaseline it doesn't take much imagination to work out what you do with the vaseline.
It must be stressed that every case is different. This remedy is not guaranteed to work for everyone. The idea is to stuff a reasonable amount of vaseline into the "vent" so that the egg will be able to slip out easily.
Here are the quick easy steps:
1.Put on a pair of thin disposable rubber gloves, of the thin surgical kind.
2.Put a big blob vaseline onto the back of your left hand. ( if you are right-handed ) The reason for doing this is for hygiene, so that you don't have to put your hand back into the vaseline jar again for a second blob of vaseline. Just keep taking the vaseline from the back of your hand instead.
3.Pick up the Bunny as gently as you can and then use your left hand (the one with the vaseline blob on the back of it) to hold her upside down by both legs leaving your other hand free. Be very careful as you are handling her because you don't want to stress her out any more than necessary and most importantly you dont want to break the egg. Most Easter Bunnies will stay still for you while they are hanging upside down. My Easter Bunny didn't move at all once she was hanging upside down.
4.Very very carefully and as slowy as you can, put blobs of vaseline inside the "vent" and wipe the vaseline around inside to give a good cover. At this point you have to be extra careful that you don't break the egg because any shards of egg shell caught inside the Bunny will cause an infection and she will die.
5.The problem egg can now be plucked.
