BIG problems
Amen. I wouldn't go Mach 8 with that combo thougfh....
The Gepetto diode fix probably saved them. Without those in place, C6 would have toasted and the reverse emitter base voltage of 50+ volts would have finished the 5172s off
The protect board itself did not cause that problem. I don't know about Newark. Mouser is our go to people. Never got a counterfeit part from them yet.
See what I mean Michael....
OK, Newark is a Canadian outfit. Hard to get stuck in customs that way.
Yes Michael, board goes out in the morning.
Yeah getting stuff shipped without encountering customs delays is more than half the problem these days.
Newark is an American company that I used in the past. Scary fast shipping, 2 days from NC, transport , taxes duties brokerage etc for a $13 flat fee, no, that is not a typo..
Unfortunately the MPSA 92 are non stock items and Mouser don't carry them so I`ll have to find them elsewhere, suggestions?
Will check but Mouser usually has them.
Joe, have they changed since the Americans were bought out??
That's what my Dad always told me Joe-----" Son, don't be afraid to buy the best, you'll never have anything to regret"
Glad you found them Mike. ON Semi is very high quality.
The output transistors are On Semi as well albeit 15024s, they should be better than the Delco`s in any case.
So there is nothing more that I can do until they get here?
I`m glad things are starting to take shape :) thanks again guys.
Did you check that the bias adjusts properly now that you have things settled down?
