Michael F
Did you solder the leads on the 2N3415 in the correct order? They are not the same as most TO-92 transistors are.
When looking at the transistor flat with leads pointing down on both transistors is E-C-B. E= Black Wire, B= Brown Wire, C= Red Wire
If they are mis-wired, you will not get the desired bias effect.
Something doesn't jive. The wires on the board end are as follows:
Red= Collector
Black= Base
Brown=Emitter
Please confirm
