The reason White Oak Audio did this was to answer numerous requests on how do I make my Phase Linear fully complementary? To do so is possible but it becomes a major backwall rewire, so major that you are better off to rip it out and start over. If you rip and start over, it is a lot of work and you still end up with poor quality sockets on the back wall and a major headache to understand the conversion instructions.
Why do people want to do it? Because it creates an amp with almost perfect circuit symmetry in design from the start to finish. Phase Linear really wanted to do this if they had the capability of doing it but in the early 70s when the amp was created, high voltage complementary pair (NPN/PNP) TO-3 transistors were not really available. In order to work around that, PL used a PNP small signal driving an NPN pre-driver followed by an NPN driver in the lower half (negative voltage side) to emulate a high voltage, power PNP transistor.
The last batch of PL400s and PL700s in the Series II were configured as full complementary output stages as the Motorola MJ15024 and MJ15025 had arrived on the scene. This emerged just prior to the end of PL production. The schematics are marked up from the quasi complementary configuration that dominated their product line for many years.
It is a better circuit configuration for a SS Class AB amplifier if the transistors exist to do it, which they do today.
