Lyle's Phase Linear 700 Ser I, to be WOPL'd
#21
DCP wired up, some wire discipline taking place. Board next, digging out the stash of silver wire of FaboNav's to do the hookup to the board.
NavLinear
#27
Nice job on the zobel network. I like how you paralleled the two resistors together and a nice touch with the cap - very shapely. Did you have to modify the resistor leads for the through-hole?
#28
Ni Dennis, it's tight but doable. The transistor standoffs are perfect!!
NavLinear
#32
THD & N, left channel....
Looking at the graph one sees a large increase in the higher frequencies but when you look at the numbers it's only 0.3% THD&N at 80 kHz! Kind of deceiving without looking a little more closely. Looking good.
#33
Got some hash on the rails, I did not put any .33uf mylars on the rail to ground connection yet. A wee bot of hi freq oscillation, even more evident on the left channel.
Spectrum Analysis, (noise floor)
#38
This phase (god I'm funny...) usually takes a week...... like Joe says..." No one test amps like you do Lee.."
#40
Nice job all around Lee...specs look good. Flirting with 200uV on the right channel, nice. We can go lower :)
