Lyle's Phase Linear 700 Ser I, to be WOPL'd
We're about to get us a suite at the CES-Las Vegas, and show off some stuff in the NFS room (not for sale ). He said after that you will not be able to keep up.....
No way - 70's technology with Joe's mods. That has to be very unusual for this show. Too cool!
Joe , you really need to post the aircraft thing in the cave somewhere, Nav would die over that one.....
BRAND NEW power switch. From Ed, and modded by ED. He had been looking for years for a bigger diameter threaded shoulder for these switches so they could put back a stock switch after having the faceplate drilled out to that 3/8 diameter. THANKS ED!!!! Your're amazing!!
Ohhhhhhhh - that sounds really tempting. Not too far from here. Keep us posted Lee!
Gotta get Joe to go. No way could I answer all those quesdtions from the amp gods when they go to askin....
He has 3 pairs of K-Horns himself, wouldn't trade em for mine, heard his and heard mine, not happenin....
Looks kinda familiar.
The knob sets it off nicely. Time to pull this puppy off line and finish it up.....
Well, it has gone past the 1 hour mark at Mach 8.5, with appropriate cool down periods for the voice coil. Justs sounds sweeter every hour those caps burn in. Don't know if I can tell the difference between this and the Pig anymore......
And the finishing touch.....
Jer, what bulbs were in the Argonnes?? There are 2 burnt out in Lyle's??
Ser I 700 teardrop pointed meters....
Yep, the Argonnes had em in the housings..
Final wiring of the faceplate and meters. Did something different this time, wired the meters on the speaker side of the DCP relays. Should take some shock out of em.
That works great. Do that on all mine
