I have relocated the bias transistor brackets more to the middle of the row, located and drilled the hole for the top board mount, this 400C had a 3 bolt holddown pattern in a V. BR wired and soldered, most of the Star ground wires prepped and terminaled, wiring rebundled so most hi volt DC over the top, low volt DC on the bottom and the AC through the middle. May be testing late tyonight.
