- Jan 14, 2011
- Gillette, Wyo.
Thanks to Fabo-Nav , I was trolling a adapter site and stumbled accross an adapter that plugs into the footprint of the HB2E-DC24 relay. On this adapter board is a sealed Panasonic SOIC, TXSA series electromechanical relay. The relay shown on the example is a 12 volt, the TXSA series does go to 24 volt DC.
The 3000 had relay issues when it was made. they tried backing off the coil voltage to 19 volts to try andd increase coil life, then the respeccing of the HB2C-Dc24 to a nitrogen filled variant, the HB2E-DC24. If you have tried to find an HB2E-DC24 you know how frustrating it can be. Her's a link to the adapter, I have not tried it but look's like it could be the answer to every 3000 Ser II owners prayers...
http://www.arieselexsac.com/products/18086.pdf
