Gibsonian's Cherry Pl 700 Ser I, soon to be a PLWO-1000
It was all the cables.... latest test. Redid them all.... Now we're gonna get Cathy all horny. These are very good numbers now Scott.
How about a set of complimentary fold away rack handles????
They'd look mighty nice on Kathy's front side. Glad it was a little old cable. Let's see what your ears say. No bad cables connecting those two transducers!
Except for some 60HZ hum i gotta track down, it sounds excellent. The bass is amazing.... I have to trim the holes in the faceplate a wee bit, but it'll be cool.
Remembered why I like the 700's on the horns, 4 notches and YOU'RE THERE!!!!! Oh, and a lot more shit leaves the walls....
That didn't take long...
Lee, that 60Hz might be coming from the protect circuit. Is that yellow pair carrying AC? If so, put a mean twist in it and see if that makes ay difference.
Mark
Or better yet, get it away from the input wiring. The amp cannot reject signal that comes in through the inputs, it treats AC like any other audio signal.
Amen guys the AC is going over the top on this one also....
Joe, if you could run through that " How to make a 60Hz receiver with the scope" thing again I would be ever so grateful...
Lee
Just clip the scope probe ground wire to the tip of the probe and use that assembly as a wand antenna. Set your scope on the most sensitive vertical setting and wand the probe around to discover radiating hot spots.
Too simple, thanks Joe!! There has got to be a repeatable procedure for finding these sources of hum in a predictable manner. At least I think there should be.
Ok folks, I am totally braindead tonight, need help. The amp IS DEAD QUIET-----=UNTIL_____ you plug in an RCA patch cord. Doesn't matter if it's on the AP, the rack or a stubbed cutoff from an ancient throwaway set. As soon as the +signal pin makes contact instant buzz, and it does not quit when the ground tangs contact the input ground surface....... F*&^%$ up input jacks???
Yah, you are up really late for good brain function. Could it be possible that there is a problem with RC network on outputs?
sHIT sCOTT i HAD A NAP FROM 8 TILL 11 I'm good to go! The zoebels are the first thing I checked. There has to be communication between sgnal plus and signal ground AND THAT covers some territory, including the front end of the board. The ground shroud on the input rca jacks are floated on this one too so a simple desdolder of the signa ground wires should eliminate the noise IF it's in the jack...
But Cathy is driving the horns right now.....
Yeah , but they only come out at night.........
