Got the LED's changed out, The power switch took some modification. Over the years the last 3 threads have been ate up necessitating moving the switch TOWARDS the faceplate. Exactly the opposite direction to get some space between the switch detent plate and the soldered LED leads. After careful consideration( a couple "Aw F^%$ it'll fit") and the Dremel cut off blade we're in business.
Also Doug the rest of the Knobbed goodies weren't lining up evenly accross the width of the plate. Custom cut some shims to go under the pot knobs, and thge meter range switch, and then had to counter bore the power switch knob. I think it turned out very well. THEY DO NOT TOUCH, but a close fit. And it won't be hard to reset the clearance, drop the knobs on the switches and tighten set screw
I like the amber color. Looks much better in person than in the pics.
I wish I had a number for the LEDS. I tried looking them up. 4.8mm or 5mm high intensity amber LEDS are easy to find. The wide dispersion seems to be the stumbing block.
