Fairchild
Sure looks pretty.
Jim
Jim
Thanks Mark! Hmmm.... just thinking out loud now.
The parts (outputs, caps, DCP) are coming tomorrow, but should I go ahead and work on swapping it out with the old one tonight? Can it still drive the original RCA/XPL outputs with no issue? At the very least, what I'm thinking is that by going ahead, I know the main outputs are "ok" as in they won't blow anything up - So I'm thinking that with them I can verify the WOPL installation is good or not? Thoughts, anyone?
Ahh... also... my favorite subject... remember that this 700 ser I is fully "stock", including the input scheme with the dual DC coupled/Cap coupled inputs. Obviously I do want to go with the DC inputs here. But also with the pots in line so I can adjust the input levels. Since those are only (right now) applied with the cap coupled input, what's the best idea? The last I remember was this below. Should this be how I do it? Should I just wire the two gnd tabs on the rca's direct to cap/star ground... or just the signal returns on the PLWO board.. or both? (or neither?)
Hi Jer
Wire as you have shown in your diagram but DO NOT connect 2L/R or the pad that connects the 2 RCA barrel grounds to the star ground. Wire 5L/R on the board to star ground only (or either one of them since you have the backside jumper installed). The 2.7 ohm resistors in location R2L/R take care of the ground for the signal grounds in the amp.
Follow the wiring diagram that I sent you that has the PL700B installation wiring.
And yes you can use this board with the existing outputs and predrivers.
Ditch the copper square and isolate the jacks from the chassis. The copper plate was PL's grounding method in the early 1970's and we know better now. Grounding the inputs together creates ground loops that act like a directional antenna for hum. Depending on the orientation of your input cables the shields will pick up 60Hz hum from your house, the transmission wires outside, or the toaster in the kitchen, etc.
