Been away for a while, spouse has been very ill. Anyways, became so frustrated with the mis behaving chassis I secured another later version from member Hexxis. So far ---
Transferred transformer and assorted bits from the old chassis to the new one, drilled and mounted main caps to end plate, installed outputs and brought her up first on a variac then dbt then mains. Sorted out a dead cap on the left driver channel and finally glorious audio. Still have to sort out the wonky meter behavior and perhaps figure out why the bias sets close to 400mv at the lowest trimmer setting but by golly its alive
Initial install before cap replacement (one of the 2.2uf axial caps left channel was open circuit)
And playing music this afternoon, need to chase down the meter issue next
Next step after that is installing the speaker protection board, then once everything tests out correctly the WOPL driver board.
First time hearing a 700 sing, you are braver souls than I am if you run them up to full rated power in a typical room
Oh, she really likes the PL-4000 preamp.
Lee, you don't remember me warning you about the original 700 back it September (Check your message on AK). Which 4000 do you have (I think I warned you about the "Joystick" Model too.... Have you had to help Phyzo lately?? I ended up selling all my Sansui 5000/A/X boards and parts after the douche bag on ebay copied my boards. I always say, if yer gonna plagiarize, at least CHANGE something....
Perry
