phase linear 400
ok...changed the ic on dcp board...
used new relay...it appears to be working...
letting it burn in a bit...
should i trust the original relay...i am afraid to check it in circuit....if anyone can/will explain a safe way to diagnose the relay????
mr. don.
thank you so much....very kind of you..
got ap rain break so far today....but ..
Do you mean the coil of the relay or the contacts?
mr. dont sent replacement relay...i repaired the board and installed new relay...it works fine... i hate to toss the old relay...as it may not be damaged....and resources are scarce here
howdy...decided to take a little getaway...9 days in the hospital...such a lovely place to visit...ended up with a trach...quite an adjustment....lololol
anybody miss me???
DONT ANSWER THAT!
LOLOL
We all missed you Gene. Take care of yourself and get better fast...
well, i fiddled with a few components on the pl14b..on one stock unit that bit the dust at the same time the wopl was brough in for repair...
as as expected and exactly as the time before...the rabbit hole just gets deeper...time to order another wopl kit...
that will leave me one stock unit...
for the time being...
and i need a few parts more from mr joe!!!
it was fun!!! i learned a lot...
