oldphaser
- Sep 8, 2012
Here is my best effort at putting into one place all the specifications for Phase Linear 700 series amplifiers (i.e. 700, 700B, 700 II and Pro 700).
NOTE: Although I attempted to load all the files so they would appear in numerical order below that doesn't appear to be the case. So please start with file number 1 (Phase Linear 700-the first 700) and work your way towards file number 27 (Phase Linear Pro700-the last 700 series amp).
These specs were obtained from Phase Linear sales brochures, owner's manuals and service manuals.
In a number of cases, there were more than (1) version of the sales brochures, owner's manuals and service manuals. The location and versions are included in the title of the documents. In most cases the versions correlate also to where Phase Linear was located at the time. They locations were as follows; 1.) Seattle, 2.) Edmonds and 3.) Lynnwood.
NOTE: I do not have a copy of the Phase Linear 700B owner's manual when they were located in Edmonds.
NOTE: I do not have complete/detailed specs for the 700HF and Kelly DeYong amps other than the 700HF was rated at 350 watts per channel both channels driven into 8 ohms from 20Hz to 100KHz at .25% THD. There are some specs also for the Clair Brothers 700B amps.
Ed
Ed
1 Phase Linear_Seattle 700 Sales Brochure Specs pg 1.pdf384.1 KB · Views: 97
2 Phase Linear_Seattle 700 Sales Brochure Specs pg 2.pdf351.3 KB · Views: 63
4 Phase Linear_Seattle 700 Owner's Manual Specs pg 1.pdf398.1 KB · Views: 48
5 Phase Linear_Seattle 700 Owner's Manual Specs pg 2.pdf381.8 KB · Views: 40
6 Phase Linear_Seattle 700 Owner's Manual Specs pg 3.pdf417.4 KB · Views: 41
7 Phase Linear_Seattle 700 Owner's Manual Specs pg 4.pdf254.8 KB · Views: 40
8 Phase Linear_Seattle 700 Owner's Manual Specs_Performance Testing pg 5.pdf606.4 KB · Views: 41
9 Phase Linear_Edmonds 700 Owner's Manual Specs pg 1.pdf620.1 KB · Views: 42
10 Phase Linear_Edmonds 700 Owner's Manual Performance Verification pg 2.pdf807.7 KB · Views: 42
11 Phase Linear_Edmonds 700 Owner's Manual Performance Verification pg 3.pdf951.1 KB · Views: 35
14 Phase Linear 700_Edmonds Service Manual Specifications pg 1.pdf595.9 KB · Views: 46
15 Phase Linear 700B_Edmonds Sales Brochure Specifications pg 1.pdf1.1 MB · Views: 47
16 Phase Linear 700B_Edmonds Sales Brochure Specifications pg 2.pdf503.9 KB · Views: 43
17 Phase Linear 700B_Lynnwood Sales Brochure Specifications pg 1.pdf593.1 KB · Views: 40
18 Phase Linear 700B_Lynnwood Owner's Manual Specifications pg 1.pdf647.1 KB · Views: 49
19 Phase Linear 700_700B Service Manual 6_76 Specifications pg 1.pdf1.3 MB · Views: 46
20 Phase Linear 700_700B Service Manual revised 2_81 Specifications pg 1.pdf1.4 MB · Views: 50
21 Phase Linear Amplifiers Series Two Sales Brochure version 1.pdf3.1 MB · Views: 57
22 Phase Linear Amplifiers Series Two Sales Brochure version 2 AMPS 79 pg 1.pdf998.6 KB · Views: 47
23 Phase Linear 700 Series Two Owner's Manual version 1 Specifications pg 1.pdf1.5 MB · Views: 51
24 Phase Linear 700 Series Two Owner's Manual version 2 157_0020_0 1279_4 Specifications pg 1.pdf749.8 KB · Views: 52
25 Phase Linear 700 Series Two Service Manual Specifications pg 1.pdf1.7 MB · Views: 54
26 Phase Linear Pro 700 Owner's Manual Specifications pg 1.pdf1.2 MB · Views: 62
27 Phase Linear Pro 700 Owner's Manual Specifications pg 2.pdf877.2 KB · Views: 70
