Huh???Thank you for the fast response. I used Joes back plane boards, so yes, I have changed both Bias Transistors, but i used NTE192 instead of 2N5088. His new boards accept both transistors? I have a spare which I'll replace tomorrow, and then report back to all.
I have NO instructions to my knowledge about the use of NTE192 transistors. They require special handling to install correctly. You should post pictures of what you did Gary. The NTE192 devices install differently than you might think. Is there a reason that you went this route instead of using the transistors provided in the kit?
