So what has been done to this amp?120 Volts
Where are you in the bring up procedure Gary? With control board or without?I have replaced to power supply using Joes capacitors and bridge rectifier. I have built the back planes panels using Joes kits. I have built a new control board with Joes kits, and I have installed your protection board inside of a new model 400 chassis. I am installing the backplanes and using Joes bring up diagram. Everything was good. I installed first roll of transistor. As I said earlier on in step 18 joe ask us to test the outputs. Without an input or output connected, I'm reading .139 ac of the left output. right side is .000. Hope this helps.
ac voltage???I have replaced to power supply using Joes capacitors and bridge rectifier. I have built the back planes panels using Joes kits. I have built a new control board with Joes kits, and I have installed your protection board inside of a new model 400 chassis. I am installing the backplanes and using Joes bring up diagram. Everything was good. I installed first roll of transistor. As I said earlier on in step 18 joe ask us to test the outputs. Without an input or output connected, I'm reading .139 ac of the left output. right side is .000. Hope this helps.
i thought the offset was checked using dc voltage??ac voltage???
Yes sir may I please have another...Joe,
I know you're going to scold me big time. I install all the transistors, wired everything together, hooked up speakers, etc. Right channel plays perfect and as loud as i want. left channel has distortion that does change with volume level.
It has got to be a missed solder joint, capacitor, or diode installed backwards. I'm going to pull the board and start comparing the good side to the bad side unless you say different.
lololololYes sir may I please have another...![]()
watching too much pornhub!!!!lolololol
I would recommend you pull the output devices from the misbehaving channel (leave the properly behaving channel in place) and observe if the output stays at 0.139VDC without any outputs installed. That will give us some clues where to look.Joe,
good catch!!!Joe,
When I removed the control board, my voltage also disappeared from the outputs. I knew its somewhere in the control board. I have a good side, so I just keep looking and measuring. Please take a look at attachment. Terminal #7 on the terminal board was not soldered. Soldered up the connection and touched up some other questionable joints. I have not remounted the control board as of yet. Wife informed me that I need to feed her. Of all the time to be hungry. Ill let everone know after work tomorrow what's happening. I hope I've found it. To everyone who's helped so far, THANKS. I'll see everyone tomorrow after work.
Gary
GaryJoe,
Gary
Just DON'T do that with both hands on alternate columns!I'm sure why I think this is funny. Buy Joe say's "Nothing we do here is wife friendly." Carmen, (my wife) asked me why I keep feeling behind my PL400. I let her know, I'm making sure temps feel right. Asked her to reach around. You and I both know that the transistors conduct electricity. Long story short, she does not think it's funny. I'm in the doghouse again....
