Thanks George
A- I will check again. I see the AC Ground wire was hooked up to the Case frame which grounds the Transformer ? I did not do these step.
1- I will have to check my AC is correct first (Check my cord and w a ac power tester also going to a my main power strips and my test power strips. and even the 120vac outlet
2- Test w and wo ground hooked up (That .2vac is really low compare to you test results)
Update 400 II
Same results if I ground the transformer the .2vac goes even lower.
Check 120vac N and Hot (is correct)
Check all winding
All wires were not Shorted to Ground -None
Winding - all Ohm out (None shorted)
all Secondary Winding to Primary - Open
George, Joe , I guess it ok? Note - Joe said "What I have found is that, generally speaking (and this all is conditioned by generally speaking because there are always exceptions)"
I will keep track when I restore more of them.
Next test - I have to temporary hook it up w rectifier and caps and check dc voltage.
