700B Build
#24
I have a question regarding preferred AC wire routing on 700B amps. I'm contemplated with respect to placing all AC wires across the middle of the backplane boards, or run AC along the top (Perry's method).
Here are my initial thoughts:
Top placement
- Greater seperation between AC and most other components
- AC closer to sensitive RCA and Control board Op Amp input circuits
Middle placement
- Potential for AC coupling to greater number of surrounding components and wiring
- Greater distance to sensitive input signals
Or, if you route AC in and out wiring closely together it makes little difference...
I don't run any AC across the boards middle of the boards. . All the AC I do goes across the top. It produced the quietest amps I've built.
Hexis22
Wisconsin
#25
Made a small change in AC wiring between the fuse holder and fan socket to keep line and neutral running together as much as possible.
I didn't like how line and neutral originally formed a loop around the DC rail fuse holders.
Before:
After:
Hexis22
Wisconsin
#27
Control board all wired up and tested without issue, +/-15V supplies measured as expected.
Lots of practice inserting outputs into backplane boards with 700's... No shorts to chassis ground and powered up cleanly with +/-104V rail voltage at 120V AC.
Set initial Bias at 350mV on both channels and output offset measured 0.000V on Left and 0.001V on Right.
Could not be more pleased with how this powered up and measured so far.
Sound test is next...
Hinodit
#36
WOW!!!!!! I must say Eric I am totaly impressed with your work. I definitely am happy with this build. I can jot wait to hear this amp. Any idea as to when.you will get the LED kit?
