here we go...unit is near pristine...listening to it now...
very happy with the purchase...
looks like the 400c board
clamp caps on power supply...
rectifier on the side too...
pl18 light board with 4 small lamps in the meters...
tell me what you think???
where to start??
where to start??
2. Then, Replace the Control board, if that's a problem, the outputs getting replaced next anyway.
3. Then do the two input big cap mod, and replace the bridge rectifier for the higher current version.
4. Last but very important, replace the output devices for the new more superior ones.
5. Then do the cosmetics, meter boards etc... Working good, is better than looking good!
6. I would add the DC blocks at the input, and volume control's. Add a power switch to the front. Bring the relay board LED to the front panel...then you always know the offset and balance is correct, and a nice "ON" indicator that all is fine.
Have fun, be patient, and you will have a great amplifier.
