- Mar 6, 2022
looks wonderful!!!
sounds challenging..OK...I'm putting together a doc for this... I'll post it later. The project is very difficult, but I think much better than the LEDs I tried. Hope you have allot of soldering skills and patience. Wont be easy sorry to say.
no sir...did not know i could do that...Gene, have you considered a cheap 2 channel DDS signal generator to calibrate your meters? Many are listed on Amazon. I use a older Koolertron model. Works on analog or digital meters.
Unlike keying up a transmitter that requires a load on the outputs, the amps require nothing on the speaker jacks.
adafruit will not ship to me...as i use a freight forwarder....Hi,
I just came up with this. There is some steps that may drive you crazy, but is a love of the amp! Maybe some one will come up with an easy add-on kit or something.
found them....on orderadafruit will not ship to me...as i use a freight forwarder....
will have to look on ebay for something similar...
they will ship to me...lololol
i do have one that is software driven (that i paid for...not freeware) ....part of the calibrated mike stuff...Gene, have you considered a cheap 2 channel DDS signal generator to calibrate your meters? Many are listed on Amazon. I use a older Koolertron model. Works on analog or digital meters.
I just found an APP Signal Audio generator. Looks perfect on the scope, and...NO, ZERO OFFSET!i do have one that is software driven (that i paid for...not freeware) ....part of the calibrated mike stuff...
but, i am sure the one you speak of is much better...will look...
Its really easy. Vertical is "loudness" in Volts per graticule, Horizontal is the period in time base per graticule / frequency info.maybe mr. george can help me learn to read scope....think it would be fun...
Gene ...take a look at thismaybe mr. george can help me learn to read scope....think it would be fun...
thank you...i certainly will!!!!Gene ...take a look at this
