Thicker PL400 faceplate with new analog meters...
What is your opinion on new PL400 thicker faceplates & new meters? You can select multiple choices
  • I like the 1/8" thick front panel faceplate that I have now
    Votes: 3 15.0%
  • I would like a thicker 3/16" front panel faceplate replacement for what I have now
    Votes: 15 75.0%
  • I like the stock PL 400 analog meters on my amp
    Votes: 3 15.0%
  • I would like a set of new, modern, more responsive analog meters for my PL400
    Votes: 16 80.0%
  • I would like a faceplate mounted 3 position meter sensitivity selection switch
    Votes: 11 55.0%
  • Total voters
    20
  • Poll closed .
grapplesaw
Vancouver
If those are stepped attenuators, isn't having only 5 positions leave some big jumps from one setting to the next? I suppose that the preamp will take up some of that. That's the one thing I didn't like about the Pro 700's. But setting the attenuators on the amp to about the 2-3 O'clock position and then using the pre made it just right. I also used a regular PL-700 pot on them in some cases.
You could be right. These are two pole 12 positions make then break pots
not sure if they can work
#22
There is an audible performance difference between an attenuator and a potentiometer.
Plus you can cherry pick the resistors that go into an attenuator. But the eBay one I got with 0.1% SM resistors sounds fantastic- WAY better than a premium Bourns pot.
#23
You can call them what you want but they do the same thing. As I said, we can find something better than a $2.00 pot.
#27
I understand the meter is backlit. Via what means? LED? Certainly not incandescent. Adjustable brilliance? I assume any backlight is powered off of the low voltage winding. is there a viewable prototype?
#28
LEDs, 14 total, 7 on each side illuminating the backlight light guide.
Fixed illumination, powered off the existing 6VAC winding of the original transformer. Meter still has the protective release liner applied to the face in these photos. IMG_6501.JPG IMG_6503.JPG IMG_6504.JPG
Vintage 700b
Wisconsin
Fabricator
#33
