Thicker PL400 faceplate with new analog meters...
What is your opinion on new PL400 thicker faceplates & new meters? You can select multiple choices
  • I like the 1/8" thick front panel faceplate that I have now
    Votes: 3 15.0%
  • I would like a thicker 3/16" front panel faceplate replacement for what I have now
    Votes: 15 75.0%
  • I like the stock PL 400 analog meters on my amp
    Votes: 3 15.0%
  • I would like a set of new, modern, more responsive analog meters for my PL400
    Votes: 16 80.0%
  • I would like a faceplate mounted 3 position meter sensitivity selection switch
    Votes: 11 55.0%
  • Total voters
    20
  • Poll closed .
#61
Survey says (thanks for all the input):
Without attenuators:
And with attenuators:
Hopefully something for everybody (even has lime green for Perry's knobs). Pilot holes are back drilled on the back of the plate in the locations shown for installing pots if desired. User will have to complete drilling them out from the backside if desired. Embodies illuminated power switch, meter range switch. If pots are added, the design is for a 32mm (1.25") diameter knob.
Love it. They grow on you after a while Joe.
#64
Actually, doing that, you could go with slightly less massive transformers, as they would require half the capacity of the single unit...
Still would be heavier than the original single I suspect.
grapplesaw
Vancouver
How about using two of these - one for the left channel & one for the right. Avel Lindberg Y236904
Mount them left and right to balance (in weight) the unit. Still would be a heavy mother.
These will be fine for a 400 in single application. Or better yet the Avel Lindberg Y236905 800VA 60V+60V Toroidal
Either of thes are Wrong voltage for 700. Need 75-0-75 for hot 700.
BlueCrab
#66
Hmm. I wonder if the transformer needs to be 75 volts to be able to put out say 400 watts. 400 watts at 8 ohms is about 57 vac (or 800 watts at 4 ohms). Rectified (with no load) a 60 volt transformer will produce a DC voltage of 85 volts. I would think this will still be adequate. As the amplifier is asked to produce more power, the load on the power supply gets heavier and I would expect the DC voltage of the power supply will get dragged down and clipping occurs. I think it's more about the VA's than the volts. 1600VA's is a lot of power.
grapplesaw
Vancouver
we are used to 200-250 watts at 8 ohms per channel with 80 v rails ( rough calculations 57v ac through bridge is 80 volt rail
to get 350-400 watts per channel you need 100 v dc rails so 72 volts minimum.
from What I remember talking to Bob Carver the transformers he uses in the 700 amps is rated over 2000va. When we approach clipping that transformer can not hold rail voltage. You do see it power out.
if you can help with the concept on dragging down rails and clipping.vs higher va transformers I’m all ears
#69
Bob has some good stuff Glen...
BlueCrab
#71
Yep, I get it now - you're right. When I looked at toroidal transformers a couple of years ago, I seem to remember some that greater voltage output on the secondary. I'll do another search.
BlueCrab
#72
Nope - can't find it. Secondary goes from 55v to 60v to 110v - nothing between 60 and 110.
How about rails of 170 volts? Eliminate the transformer altogether and go direct to the 120v (actually this puts the transformer outside your house on the power pole). Is that just too hot? Could the amp be driven with rails that high?
grapplesaw
Vancouver
Nice try. With main power first you would have 170v each rail for about 340 v Between the rails. Way over limit of transistors we use. Second very dirty signal on main supply. I just measured my main power now and it is 1.9% THD+N. With it being Saturday am it’s probably the cleanest you will get with industrial operations shut for the weekend . And third there is no insulation from the grid.
grapplesaw
Vancouver
Sorry Joe way off the topic. And on that note I’ll be picking up my faceplates for the 700 I ordered next week. Been to busy working again.I guess this will go on for an other year or so.
#75
I like to listen to you guys muse about things.
#76
Glen, I got 2 more of those toroids sitting here.
#77
The sagging of rails is primarily due to load regulation caused by ohmic losses in the transformer windings. The EI core has limited window area and limits the size (AWG) wire that can be wound successfully to fit into that window. The solution to that is to use a much larger EI core that will have a much larger window area which will allow the use of larger diameter wire. That size increase is often intolerable due to either the amount of physical space allowed or due to intolerable cost factors. PL was contending with both factors.
Other factors contribute, such as larger loss in the bridge rectifier at higher currents and more ripple in the bulk capacitor voltage leading to lower average output voltage BUT the dominant sag cause is winding losses in the transformer.
BlueCrab
#79
Sorry, I'd just like to pull on this thread a bit. Which transistors are being subject to the full + and - rail voltages? Worst case (I see) is either the + rail voltage or the - rail voltage. Not both added together.
Secondly, dirty power - isn't that dirty power just coming through the transformer attenuated a bit by the inductance and capacitance of the transformer, but surely the rectification and the bulk capacitors will remove that to whatever extent you want. You could even add line filters (better be big ones) to reduce the incoming noise.
So, here's another try (with toroidal transformers). Instead of one transformer for the right channel and one for the left, use one to generate the positive rail voltage and another transformer to make the negative rail voltage. These should work: Toroidal Transformer 75v
So it's rated at 2x35 volts at 115vac, which would be 2x38 volts at 125vac, producing between 70 and 76 volts for each leg. There are other transformers that would allow even greater rail voltages (but with decreasing current capacity).
BlueCrab
#80
I should have added 70 to 76 vac, which would give rail voltages between 99 and 107 under ideal conditions.
