Awesome work, George!So was it worth it? Oh hell yes! Absolutely no hum with volume cranked, noise floor is so low I'm hearing things I've never heard before. Bass is super tight and defined. The lower frequencies are now being passed more fully to drive the subs. Transients are sharp, sharp, sharp.
Best upgrade to the PL2000 I've made so far! Thanks Joe!
Nothing is a pretty strong word…Lee, if you look at the schematics, and research the part#s, you'll see all the transistors are Toshiba production. The 2SJ109GR and 2SK389BL dual FET are long out of production and there are no current direct replacements. There are work arounds, but nothing beats the original dual FET package.
Well, there is a company that makes a replacement for one of them, but it's a different package.Nothing is a pretty strong word…
Whenever a Japanese transistor is involved, there is always a better solution...Well, there is a company that makes a replacement for one of them, but it's a different package.
Then there's a way to use 2 FETs for the other, bonding them together.
From what I've read, the best solution is using a original.
