vince666
it looked too good to be true to finally give you back a "HUH?"
it looked too good to be true to finally give you back a "HUH?"![]()
Getting the wow and flutter downWhy would a desk be hard to adjust???
all have old pots every were, in the motor and the boards and most of them are 1-turn and are hard to adjustSteve, I don't get it..... "Like all the old Desks"?????
Thanks I will have to check my spelling Lola desk with motors, anyone?
or never post Lol
Never take a comments on Phoenix a wrong way. People here are most friendly and cool that you can find on the whole web. Guaranteed. And dont bother to check spelling, trust me, my English is far away from good. Main point is people understand you, whatever and however you ask, and will always help you as long as they can. That's how I see Phoenix. Unlikely some other forums where people can be very mean if they dont like your question or if you dont understand what they mean or if you're not agree with them.
Now back to decks. Yeah, those are 30 or more years old machines and can need some servicing. I have recaped 3 of my decks, not because it was necessary, but because they are about 30 years old. Some pots can be a problem, as you say and it's just to replace them. I start with checking SM and making a list of all parts I want to replace + some other things like soder wick, trimpots and so on. 50$ and P&P if free
Regarding polarized and bipolar caps, I do replace polarized with bipolar caps, only in a signal path where 0v is presented. I cant argue if it gives a difference but people say it's better with bipolars so why not. Of course, nothing wrong to replace with equal type. I think I'll recap my 2nd RS-B965 with the same as it came from the factory.
Furthermore, if I remember correctly it was Aiwa that used some polarized caps in bipolar configuration (the known way) at some decks. If I remember correctly...
Yes, Vince! Correct! (Thank God, I still keep my mind!)
If Aiwa chose to use bipolar configuration at the signal path, maybe it's a proof it does make some difference.
