 - Mar 6, 2022
mr. joe...
thank you....
i put the writing up...never considered the reverse...Gene, is the snubber board upside down? Mine are the other way so the caps are tucked under.
first of many...i am sure...
joe said the board was upside down...Writing UP, caps on the other side
but i see your point....i am not cramped for space since it is a wall mounted rectifier...
better????Writing UP, caps on the other side
better????point taken...still have two more to do...both are 8 fins...with the cradles...will try to do better...
thanks so much for the advice!!!
you want wall...nut..standoff...board...nylon washer...nut...did i understand you right??I suggest a nut under each of the plastic control board standoffs. Keeps those long screws secure. You also gain 1 nut width of extra spacing away from the backplanes. Should be enough thread left to use a nylon washer and nut after the control board is mounted.
Those long plastic standoffs tend to "relax".
Bingo !better????
better????
how about this mr. george??you want wall...nut..standoff...board...nylon washer...nut...did i understand you right??
