 - Mar 6, 2022
got the new to me 8 fin in today....
pretty rough....the meters had slid down out of the holders....inside has stuff growing in there....looks like gaulded aluminum specks ....
pulled all of the drivers and outputs....all of the outputs tested bad...but in a strange way....showed shorted b to e....and not any other way...
i just dont have enough experience to recognize any significance if there is any....
the two agx fuse caps were missing...thankfully mr. george put two in a care package he sent to me when i made a donation for a 14b board...
saved the day mr. george....
all of the driver transistors tested good...
bias transistors tested good...
did not go much farther....
big caps showed 7500 uf....
nothing puffy showing...
want to check the transformer and rectifier....but unsure how since the blown/missing fuses....dont want to do any more damage...
i believe that the fuses were bypassed....since it got both sides in the same way...just a guess...but, i am sure you all have figured that out...
i need to order the ps caps and led upgrade from mr. joe......but want to make sure the transformer is good .... will just probably get a snubber rectifier from mr. joe...they are cheap enough....
just to be sure...
i think i have enough 909s to repopulate...to see if it will run....
no other obvious burns/shorts/damage showing...
any advice how to proceed to check the transformer without burning up anything else...????
the meters are dixon....someone has been into them...mounting screws missing...the faceplate bent to touch the needle....
burn marks from the bulbs...but normal i would think...and loose bulbs broken bulbs inside the meters....
maybe a good cleaning/lube will help them along...
would appreciate any comments or advice....
thanks ....
just to be sure...
thanks ....
