MusicSteve
Gene
Did you check the four .5amp fuses that go the the control board yet?
i checked all fuses....the four on the backplanes and the three in the main amp chassis....one 5amp agx fuse was bad...but, you could not tell it...Gene
wasnt actually a kaboom....was more of a pfffftttt....
You have to do it by hand and roll it around just a little bit. I get a single clean chip with my Cleveland 100 degree countersink bit mounted in a hand chuck.The one thing I learned to not do is try to machine a chamfer. Even a tapered reamer leaves a ridge that needs sandpapered off.
i am sure that was part of the problem...in joes docs he warned about dull punches used by phase linear...i did not reuse the sil pads when the problem reassembly started...i have a calibrated wrist...i set it to snug...not tight ...not loose...i have a bit more 1/16 " of the legs pokin through the back planes...clearly sufficient contact...i dont think anything else was wrong....just three outputs bad...Gene,
I always remove the heat sinks and take a flat file to the transistor seating surfaces. If it is flat, the file just glides on the dark anodizing. If there is a high spot from a defect or a dent where some goofball dropped something onto the soft aluminum surface; it shows up. Then I chamfer each hole that a Sil-Pad would be touching, and never re-use a Sil-Pad, they are not very expensive.
I have had several heat sinks with high spots that were likely burn-through pits and craters, these would likely have pushed through a Sil-Pad. I resisted Sil-Pads for a long time because I was a Mica and Grease man. Eventually, Joe convinced me about the time-saving qualities of the Sil-Pads, but nothing will push through a sheet of mica.
And, I torque each screw to 7 inch-pounds with a calibrated torque screwdriver. I have not since had any problems with my flattened, chamfered heat sinks and Sil-Pad interfaces.
i did not put countersink/champher bit in a drill...only by hand...dont take much..You have to do it by hand and roll it around just a little bit. I get a single clean chip with my Cleveland 100 degree countersink bit mounted in a hand chuck.
Big time...would using 2 sil pads disrupt heat transfer to the heatsinks?
i think that it would...
are sil pads more efficient than mica/compound,???Big time...
Bothare sil pads more efficient than mica/compound,???
or just more convenient??
they sure are more esthetically pleasing, for sure!!Both
you really dont realize how much i enjoy this!!!Gene, if your going to pull the bell to install a foot, you may as well upgrade your bolts to use the step washers. Also consider Phoenix Contacts on the backplanes. A strip of fine grit wet/dry under you fingertip with proof your heatsinks easily and quickly. Have fun!
We should consolidate all of George's outstanding advice/tip posts into a "GeorgeS Wisdom" sticky! in the WOPL Building forum. Lots of great info scattered within his posts.you really dont realize how much i enjoy this!!!
thanks for the tips!!!
