- Mar 6, 2022
please!!!Kyle's a good resource to have to look at your build.
You can safely proceed to bring up IF you put a small wire jumper between the C-E terminals on the back side of the control board Phoenix connector whilst you await the arrival of the replacement bias transistors. You will have zero bias which does not matter for basic operation.done for today...not much more i can do without the bias transistors....wont be long now...bias transistors in the road!!!
more chum!!!
do i populate the back planes??You can safely proceed to bring up IF you put a small wire jumper between the C-E terminals on the back side of the control board Phoenix connector whilst you await the arrival of the replacement bias transistors. You will have zero bias which does not matter for basic operation.
yes sir....And really study Kyle's build thread photos and the issues he ran into. He has really good photos and documented some issues and solutions he ran into. Very good study material now that you've learned more about WOPLs.
If I ever have extra S1 meters I'm going to send him a pair.
i quit hours ago ....Don't rush it. Call it a day and study Kyle's thread and PDFs. Slow down.
there is nos meters on ebay...but you can find an entire 400 cheaper...lolAnd really study Kyle's build thread photos and the issues he ran into. He has really good photos and documented some issues and solutions he ran into. Very good study material now that you've learned more about WOPLs.
Either works Gene, there is nothing connected at the other end of those 3 wires so you can either leave them in the 3 position connector and add the C-E jumper on the control board or remove those three wires and tape them off and add the C-E jumperone other question....
when i hook up c-e jumpers in the phoenix plug on the back of the control board....
do i do that with the 3 bias wires red, black, brown connected to the phoenix connector ???
or do i do this with the 3 bias wires isolated and taped up....
thanks to the powers that be this morning...
Offset is always across the speaker jacks. The DCP will need to click in before you get a connection however. It should kick in.not directly stated in docs...but offset is across speaker jacks as in stock 400??
sorry about stupid questions...i dont want to make sniffs day...
