Got a PL 700 ii ebay arrived bent chassis Never tested Bent up
Replaced Chassis remounted with all New matched Output transistors and new Main Power supply CAPS from WO
Did a Vari ac soft start up all went well 90 VDC + & - on both rails this never faulters during intermittent failure always perfect
Intermittent issue noted on power up this is what happens on Bad power up
( A ) Bias on both channels starts normal ( .3666 VDC ) then after 2 - 3 seconds goes near Zero VDC ( .0001 VDC )
( B ) At same time Offset ( ON BOTH CHANNELS ) starts at Near ( .0001 VDC ) but after same time 2 -3 seconds goes to ( +28 VDC ) instant then slowly drops about 1 vdc every 3 seconds until it actually flips polarity then continues to rise VDC in reverse polarity about a 1 VDC every 10 seconds.
Alternatively on good start up ( simply resetting power switch ) all is well and stable on both Channels remains stable for a hour
Does this random
IDEAS ?
Does this random
IDEAS ?
