PL 700 ii Strange Bias and Offset !! ??
Greg
Got a PL 700 ii ebay arrived bent chassis Never tested Bent up
Replaced Chassis remounted with all New matched Output transistors and new Main Power supply CAPS from WO
Did a Vari ac soft start up all went well 90 VDC + & - on both rails this never faulters during intermittent failure always perfect
Intermittent issue noted on power up this is what happens on Bad power up
( A ) Bias on both channels starts normal ( .3666 VDC ) then after 2 - 3 seconds goes near Zero VDC ( .0001 VDC )
( B ) At same time Offset ( ON BOTH CHANNELS ) starts at Near ( .0001 VDC ) but after same time 2 -3 seconds goes to ( +28 VDC ) instant then slowly drops about 1 vdc every 3 seconds until it actually flips polarity then continues to rise VDC in reverse polarity about a 1 VDC every 10 seconds.
Alternatively on good start up ( simply resetting power switch ) all is well and stable on both Channels remains stable for a hour
Does this random
IDEAS ?
grapplesaw
Vancouver
welcom to the site
was this a full complimentary amp from the factory or has it been converted by you or someone else? What drivers are installed?
More shots of backplate please
with both channels doing this identically you may fist want to check your meter Connections
Greg
Hello Thanks for interest
The Pl 700 Arrrived as a bit of a Frankenstein
All I have done is replaced all the Main output power transistors as per images
I replaced The main Caps
I replaced The Frame / Chassis
I did NOT Pretest with damaged / Bent Chassis
Its Strange occurrence I have Checked and validated My meter ( FLUKE ) connections against a ( VDC battery ) all seems well
As stated The BIAS ( voltage drop across R 109 (( 10 ohm )) goes Zero at same time the near 28 VDC appears on the Out put channels ( offset ) for both A and B channels ??? in about the 3 second mark
Thanks for any ideas !
Greg if you posted pictures that are capable of being zoomed in on, it would help this community to help you.
Greg
Ok I have reposted images thank you I chose the full image format hope this helps
Minnesota
General checks
Double check that OP-amp they should be the same, you have a LM351 , what's that other one?
check Zennor diodes for +15vdc and -15vdc
check voltage between each speaker terminals + and - (LT and RT speaker outupts)
check DC voltage after fuses or backplane.
Might want to run the channel w the LM351 and take the rail fuse out for the other channel
Minnesota
What Value are the Sand resistors? should be 7.5k
What was the description for the amp working or not?
The Diodes look funny (might want to check all of them)
Greg
Yes well noted the Diodes odd as well. Parts just arrived today will apply repairs and update parts and see how issue progresses
Thanks, much better. Your control board has the famous Rockwood wirewound resistors on it. Those are a known high failure item.
Not your current problem but the Zoebel resistors should never be a wirewound type. Too inductive and defeats the purpose of a Zoebel.
Minnesota
Yes but you have to change the R1 and R2 , Looks like you need a 1.8k 5w for the LM356. Might want to add Sockets for the Op-amps.
Greg
Thanks all for suggestions I will do in the following order rather than shot gun the whole deal if seems and retest after each repair
I am also inclined to install the DC speaker protection relay rather than use my speakers as a test
1. remove ground wire
2. Recap PL36
3. Replace op amps and diodes same time
4. bias transistors replace
Greg
Minnesota
2. Recap PL36
Greg
Greg
Sounds Like a Plan.
Very good Idea
I am also inclined to install the DC speaker protection relay rather than use my speakers as a test (still might want to use 2x 8 ohm resistor as your speakers)
Gook luck
Steve
2. Recap PL36
Greg
Did you check your +/- 15V supplies Greg? Both channels share a common power supply and you indicated both channels are acting up, generally leading to the shared area. Those 7.5K resistors are that power supply.
You should really find out what is up before swapping out parts.
Greg
Very good Idea !! Thank you very much I will put that at top of list. Yes it must be part of the shared cct because everything happens at same time both channels !!??
Greg
Dropping 15.5 VDC across each 7.5 K resistor so seems ok
