MusicSteve
SnifferI fought the switchover from Rosin to No-Clean for a LONG time. Now I only use the Rosin flux for untinned components/wires and some of the crusty shit in PL's
I would think you would not need much Flux w a new board if any?
so w the No clean solder and a little bit of the Kester 951 would be the perfect match?
I think that paste flux and like you said would create mess and would defeat the whole Clean solder joint.
Thanks
 Headband Magnifier Glass w 2 double sided lens in them (one will flip up and you can use one) , I don't like the ones w the lights they add to much weight and they don't seem to last very long before the led wires break.
