DIY no-clean-style flux
2019-06-06
SDIY chemistry science!
My two previous DIY solder flux formulations are both designed to be cleaned away after use, with
alcohol or with
water. In both cases the cleaning is more or less necessary: traditional resin leaves a sticky residue that will attract water, and the citric-acid water-wash flux remains active and corrosive at room temperature, so it will damage boards if left in place. But there are many solder joints, such as those involving stranded wire or liquid-trapping components like potentiometers, that cannot or should not be cleaned after soldering. Those mandate a
no-clean flux.
The flux I'm describing here is somewhat experimental. It is partially inspired by
US Patent 5,297,721, but also incorporates some ideas from other patents, known formulations of commercial fluxes, and the compromises necessary to make it something you can reasonably mix up in a home lab. Please note that fluxes similar to this one are sold on the claim that they work without cleaning, but I'm not sure I want to commit to that really working, and so I am calling it "no-clean style" rather than promising that it will really work perfectly well without cleaning.  In my testing,
residues from fluxes made to this formulation have allowed significant leakage currents that might interfere with circuit operation.  It may be better to treat this as a water-wash flux.  See
my next article for the test results.
Laxatives and supplements
As described in
the first article of this series, one of the fundamental flux ingredients is the
resin: a gooey or plastic-like substance that will become a thin liquid under soldering heat and flow out onto the joint, possibly carrying other ingredients with it. Pine rosin, or the resin from which it is derived, is the old standby for this purpose. Synthetic fluxes that avoid rosin often replace it with polyethylene glycol (PEG). The paste filling of no-clean flux-core solder is often just some grade of PEG, possibly with a small amount of an activator added, much as rosin flux might contain an activator.
Polyethylene glycol is not to be confused with ethylene glycol, commonly used in antifreeze. The connection between them is theoretical: PEG has the structure that would result if you joined molecules of ethylene glycol into a polymer, and that determines its name, but PEG is not in fact manufactured by polymerizing ethylene glycol in practice, but rather by polymerizing ethylene oxide.
The properties of PEG vary depending on how many ethylene oxide molecules were joined to create each PEG molecule, so when PEG is used in industry, it's not just "PEG" but PEG with some number, such as "PEG 400" or "PEG 3350." Each of these will inevitably be a mixture of different-sixed molecules, but the number describes the target value for the
average molecular weight. With PEG 3350, each PEG molecule has about 76 ethylene oxide units in it.
PEGs up to about 1000 are liquid at room temperature (getting thicker and stickier as the number increases). They tend to be good solvents that will mix with both oil and water. Many fluxes use a low-molecular-weight PEG as the main solvent and dissolve whatever other ingredients are required into it. Past molecular weight 1000, we're dealing with solids, which go from soft and waxy up to hard and plastic-like; but they remain water-soluble even up to very high molecular weight. All the PEGs are basically non-toxic, and they're commonly used in a number of pharmaceutical and food-additive applications, for stuff like coating pills. They also have many niche uses - for instance, woodworkers and archaeologists sometimes stabilize wood by soaking it in PEG 400 or PEG 1000 to replace the water with something that won't evaporate.
I wanted to use a solid PEG as the resin in my no-clean flux formulation, but I was faced with how to obtain that and how to direct do-it-yourselfers to do the same. The answer turned out to be PEG 3350. It's commonly sold in drugstores as an over-the-counter laxative. The intended use is that you mix 17g of this stuff (which is a substantial amount) into a drink, swallow it, do that once a day, and it keeps everything moving. It is basically an artificial form of dietary fibre: something that won't be absorbed in your intestines and creates osmotic pressure, limiting water absorption. In many places you can buy pure PEG 3350 powder for this purpose quite cheaply under a name like "ClearLax," "RestoraLax," or "Macrogol."
In researching this, I learned that another common medical product is "PEG 3350 with electrolytes," often sold under the name "Colyte." That's used as a laxative and to flush out the intestines before procedures like colonoscopy, I think. I'm not sure that the "with electrolytes" version is commonly sold over-the-counter, that is, to the general public. But my guess is that in some places it may be possible to find that and not pure PEG; and if you were in that situation, you'd have a bit of an issue because the "electrolytes" are going to be things like sodium chloride. Any chloride is bad news in a no-clean flux because it will support corrosion.
So even though I'm not sure how applicable this is to most readers, I ended up doing an experiment on purifying PEG by
removing the electrolytes from a "with electrolytes" product. If you need to do that, or just find the subject interesting, you can go watch the video for it.
Unlike rosin, PEG is not self-activating. If we use it alone on a solder joint, it will only have a very limited fluxing effect. We need to add something else to activate it, and the activator should ideally be something that will function as an acid or other corrosive kind of chemical at high temperatures, but be well-behaved and neutral at room temperature. It also, obviously, has to be something we can actually obtain, not too poisonous, compatible with whatever we're using as solvent (in this case, water), and so on.
Citric acid, the main activator in the
water-wash flux from last entry, might be one good choice. I ended up putting a little bit of that in my no-clean flux because I hope that in small amounts it will help reduce corrosion by chelating metals (especially when the flux is formulated with tap water). I feel justified in using it as one ingredient of a no-clean flux because it's recommended as such in
that patent I mentioned before. But I think it's too corrosive to be the main activator, or used in larger quantities.
Instead, I opted to make the main activator be some form of
amino acid. An amino acid in general contains both an organic acid group and an amine (which functions as a base, the opposite of an acid) in the same molecule. At low temperatures they basically neutralize each other, making the substance relatively inactive. At high temperatures, both groups become active, giving the effect of both an organic acid flux activator and an amine activator in the same ingredient. That's what it takes to be a good activator for no-clean flux.
And the other really nice thing about amino acids is that they are non-toxic and easy to obtain. You can get a whole menu of food-grade pure amino acid powders at relatively low prices from a "sports nutrition" vendor, because some athletes, body-builders, and so on like to consume pure amino acids as dietary supplements, hoping to get some kind of performance enhancement. (I'm not going to comment very much on that, but you might ask yourself: if these products really worked as performance enhancers, then why aren't they banned as drugs by the sports governing
