- Jan 14, 2011
- Gillette, Wyo.
Who makes the racks Spence?
I built them, designed them and had a company called Framing Technology cut everything for me. They are aluminum T slot frames and I used black vinyl car wrap on the outside surfaces. Had a local glass company cut all the tempered glass and I tinted them with limo tint. I use rubber disks between the glass and the frame. The three frames are bolted together, there are felt furniture slider disks between the frames and the floor. I needed something that I could adjust the shelving heights as my systems changed and could support a lot of weight. I am very happy with the results.Who makes the racks Spence?
I could rip it to CD for you. Pretty clean record.
I happened to pickup Billy's autobiography "Dancing With Myself" several years ago. It's a good read.It's Billy again today. Always cheers me up.
1990 Billy Idol - Charmed Life.
Mark Younger-Smith's guitar work is exemplary, as usual.
Production is faultless.
Nasty ported speakers bad, Epi's goooooood! Chainsaw ahead...
