Check out the Rean (Neutrik) brand ones at Mouser. Good quality and about $2 each.
That is going to pair nicely with your new D500 after you get it built.That's the route I ended up going, Jim .... View attachment 65358
GeorgeThe pin vise is pointing to a CDE silver mica capacitor. Joe said to use these for the smaller values. He didn't say why, so I researched why. They are very expensive! The higher the value the higher the cost.
So, have to use electrolytic where a film would just be too large to fit, silver mica where it makes economic sense, and film everywhere else. No ceramic capacitors allowed on the board.
Well, ceramics are usually not real accurately made with a wide tolerance. Given where a manufacturer used them, generally not a issue, but some of the ones I've pulled out of the PL1000 S2 I'm currently working on are far off spec, probably because of age and cheapness.
I use silver mica to replace them because they're generally thought to be very stable, long lived in that epoxy coating, and very accurate in value. Some "audiophiles" say they can tell the difference in sound between silver mica or film. But that's not me, I'm not one of them. My philosophy is build it once with the best parts and price that makes sense.
Lastly, Joe has said ceramics are terrible in audio and PL cut costs by using them and electrolytics where they could. From the help the forum gave me on my journey to learning how to on the preamps, I can condense it to this. No ceramics allowed, use silver mica for the lower values but watch cost, use film where silver mica is too expensive or won't fit due to size for replacing a electrolytic. Use electrolytics where nothing else will work. That's my philosophy. Would be great to hear other options please! I'm wanting and willing to learn.
ThanksWell, ceramics are usually not real accurately made with a wide tolerance. Given where a manufacturer used them, generally not a issue, but some of the ones I've pulled out of the PL1000 S2 I'm currently working on are far off spec, probably because of age and cheapness.
I also been using the WIMA for .47uf or lessOh, and TDK films are also supposed to be very good. I used them for snubbers on the preamps and Mark L. said he's using 40 something uF TDK films on the outputs of his PL2000 preamp. They must be huge! Mark L., please post a photo of them if you read this and and are able.j
The price is right. I'd just be concerned about lead diameter for through holes. Easy enough to enlarge them with proper sized bit and pin vise, just go slow from the foil side and don't allow a burr to develop that causes the solder pad to twist free of the board. The PL2000 preamp boards had many non standard undersized holes that needed enlarged. Using 100 V silver mica caps on the PL1000 S2 because they have small diameter leads. No drilling needed so far. Same goes film caps.I also been using the WIMA for .47uf or less
Here another source for Silver Mica Capacitor from Parts Express, I Been buying the Miflex KPCU 0.10uF 600VDC Copper foil Poly/Paper in Oil for my Speaker crossover Bypass. I been buying them when on sale (they just double in prices now I glad I stocked up) so I think these are good? , I will find out what do think?
Silver Mica Film Capacitors (partsconnexion.com)
Mark, is that a .01 uF cap on the RC4739 Browndogs? Did you also bypass the RC4136? That's slick how you mounted the bypass cap. Thanks for the photo. Can't remember the value I'm running at the outputs, probably about 4-5 uF and I remember Joe saying it would be beneficial to increase it.I tried the 47uF caps and they were just too big. I settled for these TDK 22uF 63VDC film caps and they fit perfectly.
Here is the Mouser P/N: 871-B32523R226M. They are $4.39 each, which is not too bad for what you get.
And the sound - beautiful.
George, my brain knew what I was saying, but it did not come out correctly.wiring a 4.7M 1/4W resistor across each of your DC-blocking output capacitors
