They’re socketed!!! Pull the two screws each output and pull them out with magnet or needle nose pliers.The idea of having to resolder those joints was giving me pause.
 F%#$ I'm glad I joined.  THANK YOU!!!!
  F%#$ I'm glad I joined.  THANK YOU!!!!WHAT???!!! HA! AwesomeF%#$ I'm glad I joined. THANK YOU!!!!
Whatever you do, do not read this page from the service manual.
 But it did give me the chance to do more cleaning.
  But it did give me the chance to do more cleaning.in PL400's the rail fuses are shared between both channels. The PL700's had fuses for each channel.Yes 2 rail fuses. And yes I did all 6 tests. So the fuses aren't for each channel I'm guessing right? Implying that the blown OTs were one from each rail?
So, when I replace those I need to "recalibrate" using the Oscope, signal generator, etc
Hi Drew
No. Once you get healthy outputs installed, you will only need a DMM to bring it back, check the offset and set the bias. When you bring back up, do it on a DBT so you can tell if things are OK or not. Turn your bias pots to minimum, full CCW upon DBT bring up.
What do you have in the back wall right now, have you posted pics of what is in there?
TP9054s are just MJ15024s that have been private labeled for Phase Linear.
MJ21196G devices are superior to the MJ15024
