Now following Joe's "Back Plane Bring Up Recommendations" PDF. For those who are new to this, we plug a Variac into the wall, then a Dim Bulb Tester between the Variac and amp.
I like to make the simplest DBT using a 3 wire extension cord. I strip about 4" of insulation off, cut the black wire only, and wire in a 100 watt incandescent light bulb to the two ends.
Any shorts that draw current will light the bulb as voltage is increased on the Variac. The light bulb will take that current saving the amp from errors.
The DCP relays engaged at 80 VAC, that's good.
It's sat here for 10 minutes with power on it. The filiments in the bulb are just barely glowing.
Going to shut it down, discharge the caps, and do the next steps that involve putting in the first row of outputs
