I might have a problem.
Checking voltages on the solid yellow, orange, and gray(it was capped unused) wires coming out of the transformer with aim to power the 12 VAC  WOAD Cylon meters connections AC1 and AC2.
Orange is 44 VAC, yellow is 35 VAC, grey 39 VAC. Meter is between the wire and the secondary center tap. A second backup meter shows same results.
Only the main fuse is in, no rail fuses, caps are connected.
Wondering if I need to assemble the amp further along and this will "pull down" those high AC voltages or if I have a different issue.
B- is -102 VDC, B+ is +102 VDC.
I feel I'm overlooking something simple. Just can't figure out what.
