e30m3mon
And Lee - I will set the bias as suggested. thanks
The original coax used by PL is actually shielded twisted pair and not coax. It is made by Belden. It is horrible to work with because it suffers melt back with the application of any heat. I always replace with high quality RG316 type teflon coax. Smaller diameter also makes it dress more nicely.Good while back Perry stated in a post that the variable attenuators(pots) have no effect on signal quality. Being that they can be bypassed completely like a original S1 that doesn't have them, or left in circuit like a S2. He said he tested both ways, got same results. I believe him even after he said he hires a Wino to do his builds! Hope he isn't getting over run from the border being open.
Al, however, what markings are on that black coax your using? Someone more knowledgeable than me can confirm it's appropriate as there are various impedances and types.
The original coax should be Belden branded and I've read it's good enough to reuse in a WOPL.
I looked closely at this cable and see no markings...I think that's odd as well. My friend will go to his storage shed and see if he can locate the original spool, but he assures me it is a high quality, low loss cable that he has used for years with high end equipment.
But the bottom line is that I got it all together this afternoon - and powered up! Aja NEVER sounded this GOOD ! I have been holding back from taking the volume up too high just yet, but I will get there soon enough!
Question for Joe ... how hot will those .33ohm emitter resistors get during high-demand volume levels? I have one of the coax cables routed where it is close to one of them.
MANY, MANY thanks to this awesome community! From the onset when I posted my introduction, the welcomes and helpful advice have been amazing. Joe has developed the most amazing product line for these old PL boxes. I have a local friend with a 400-II that is going to be very impressed with this reborn system.
Next project might be a P3600 pre-amp that was given to me. Immediate problem is that ridiculous ribbon cable between boards; it is delaminated in several spots. Not sure if it is worth the time investment...but it is a project and folks out here seem to like the phono pre-amp section ( I searched !)
Pics attached:
Al
And that aint for long...The only time they get hot Al is when an output shorts..
This is very high quality coaxial cable perfect for the input signal wires for Phase Linear amplifiers.I always replace with high quality RG316 type teflon coax.
