- Jan 14, 2011
- Gillette, Wyo.
so it is just 700ii and d500 parts thrown together
Yep...
Looks like you have a carver c-500 as one of the units for sale. I have two now fully converted. They are the same output as a phase linear 400.the one that claims to be a prototype makes me think of dual/d500 pro version if such a thing ever was made that pro700 would go nice with my clair
I will also take the rack handles from that one clair listing since my face is held on with wire ties
This is truly a messed up amp. The back plate and control board from the d500. The transformer has now two bridge rectifierS. One for low rail and one for high rail output. The rectifiers feed their own power caps so large set runs on 120 volt rail and the smaller pair in the middle run at 80 volts. looks like the DCP and feed back safety systems the d500 had have been removed. Meters are from 700 as seen at meter plates showing power output graduate And 350 watts output.the one that claims to be a prototype makes me think of dual/d500 pro version if such a thing ever was made that pro700 would go nice with my clair
c-500 and series 1 and series ll 400 have exactly the same power output all run on 80 volt rails.yes the seller has a c500 and an original and series i what ever you want to call it 700 (12 outputs) not 24 on b and ii a long with the 2 clairs pro700 and the (700 d500) mixed parts amp. would not be surprised of they were obtained for a song and now seller thinks they have a gold mine
do not know about these amps but have been told the seller is a BS artist
I assume CSY are Clyde's initials.The CSY 1.5 was built bby Clyde Yamomoto from pilfered parts from PL. Not a reliable amp at all...stay plumb away from that mess. treasurehunt474 or what ever his name is bought all the amps that the feller teased us with a month ago. Wayyyyy overpriced and misleading to boot...
I looked a little closer and found so many missed steps. It is fully complementary now. Most outputs replaced in 2003 but first row outputs are very suspect mj11013/14 instead of Mj21195/96. See attached spec.c-500 and series 1 and series ll 400 have exactly the same power output all run on 80 volt rails.
when Bob and carver corp built these he had to change enough stuff to avoid law suite from phase linear.
I have gutted the c-500’s and gone full complementary with white oak control boards and don‘s dcp . There is thread on the build out there. I put together some kits for a couple of happy customers along the way. Also added a power buttonView attachment 48383
other then the face what is the difference between a clair 700 and a pro 700
Inefficiendt way to expand heatsinks.I like the resistors to nowhere that are mounted inside that amp...
Location is Lancaster, PA. Unless they've moved, Clair is in Lancaster.
