Some pictures of the WO Backplane installation - got a few hours to get the wires cut and soldered onto the boards, and then set into place. I like how Joe reminds us to clean the back side as these will be installed "for the next 40 years". After getting all those wires routed, I never want to take these out! Speaking of which ... Mark's comment about the wires lengths being perfect and not to add anything got me thinking..."damn these wires are long". So I got creative about routing them around the perimeter, bends and such in such a way to keep the AC wires away from the DC wires, and then then keeping the DC ground wires separate from the DC voltage wires, best I could - or so I thought would work well when everything was reassembled. I also recall reading (somewhere) about how critical the wire routing and keeping things tidy inside amplifiers is to keep noise down. I took a shot at how i though all that wire could be best tucked and routed. The good news is the initial phase of bring-up went without a hitch....figured I'd let the capacitors discharge on their own while I got this note out.
Also note I mounted Don's DCP board so I could route the wires that will eventually be connected to it after the backplane is populated and bias set.
Something I have been meaning to ask, and since I will install the drivers in the morning...how critical is it to have transistors paired correctly, by gain I presume? Reason I ask, is that the bottoms of the MJ 21195s are not marked, but (6) of my MJ21196s are labeled "950" and the other (6) are labeled "970". Will it matter which (6) of the MJ21196s I select to use with the (6) MJ21195s ? Guessing these are the gain values for these transistors?
Many thanks guys
Al
