62vauxhall
- May 14, 2014
- Southwest Kootenays BC
Hoping for some general info concerning a dual mono Rotel RA-1412 integrated.
Both power supplies have been made to work but the Protection circuit will not disengage. Unless the left main amplifier board is disconnected.
As far as I have been able to tell, there is nothing wrong with that board. All components are good and nothing wrong on the trace side. And with the left channel main amplifer disconnected, the right channel works fine.
~60 volts exits the left main amp board at pin 5 to the Protection circuit when it's connected and it should be (near) zero as it is with the right main amplifier board.
All four output transistors were removed from the left channel thinking I could "trouble shoot" without them. Two are blown anyway but the other two are OK.
I am tempted to re-install the two good output transistors to see if that stops the ~60 volts exiting the left main amp board to the protection circuit. But I am unsure if the transistors need to be horizontal or vertical.
